Clears a slot of a previously assigned switch type.
| slot | Specifies a slot (node) on a SummitStack. |
N/A.
If you issue the unconfigure ports wan-phy command on a slot containing a switch with any ports configured for software-controlled redundancy, this command wipes away all software-controlled redundancy on both ports; both ports return to normal. Refer to the Switch Engine v33.1.1 User Guide for more information on software-controlled redundant ports.
The following command clears node (slot) 4 of a previously assigned switch type:
unconfigure slot 4
This command is available only on SummitStack.
